Self-Help Articles
How to Install a Certificate on SZ/vSZ?
How to Install a Certificate on SZ/vSZ? Generate the CSR from any node, or the same can be generated from a third part device: System >> Certificates >> CSR >> Generate Fill in the details and submit the same to a CA authority Now, you will be able...
remya_murugesh_0-1656526482177.png remya_murugesh_1-1656526482182.png remya_murugesh_2-1656526482186.png remya_murugesh_3-1656526482188.png
Converting Access Point from SmartZone to Ruckus Cloud
As a Ruckus TAC engineer, I would like to share my experience with the process of converting AP from SmartZone to the Ruckus cloud. APs running firmware 3.6 or later versions are enabled for the cloud discovery process and can migrate to cloud withou...
tech_buddy_0-1655565565039.png tech_buddy_1-1655565565045.png tech_buddy_2-1655565565055.png tech_buddy_3-1655565565070.png
_Mudit by New Contributor
  • 5517 Views
  • 0 replies
  • 5 kudos
Correct way to factory reset an SZ100, SZ104, SZ124, SZ144
Note: Pressing and holding of the reset button will not factory reset the device, this will only restart the device Button 4 is called the f/d button which factory-defaults / factory-resets the devicePress and hold for 10 seconds to activate the rese...
Migrating ZD managed APs to vSZ
  Introduction : This article is focused on explaining the requirement and process to move AP's from your existing ZD platform to virtual platform "vSZ/SZ". This would cover your pre-requisite and supported user scenario's. Since there are a lot diff...
Vineet_nejwala_0-1654137153755.png Vineet_nejwala_1-1654139504783.png UI1.PNG UI3.PNG
How to identify and validate the vSZ resource requirements?
vSZ requires enough hardware resources to sustain the service. vSZ cannot support deployment in low performance hypervisor. During the time of deployment or upgrade it is always a good practice to reconfirm and validate the resource requirements of v...
