Self-Help Articles
Data Center Migration from Hongkong to Singapore
Pre-checks on migrations:Make sure that all switches and APs added on cloud should be operational.Make sure to whitelist below IPs/FQDNs on your firewall outbound rules:           IP range: 34.87.82.64 through 34.87.82.95, ports: tcp 443 & 22        ...
_Mudit by New Contributor
  • 2592 Views
  • 0 replies
Configuring your Unleashed system for Sonos Subwoofer or Stereo pair
This guide will explain, in details, how to disable two parameters that will cause that your Sonos devices can't pair with each other.   Command                             Explanation set qos eth0 directed multicast disable   This prevents the W...
Yarenis by Moderator
  • 2152 Views
  • 0 replies
  • 0 kudos
Israel Country Code missing DFS channels
DFS channels have been approved by the Israel telecommunication authorities for some time. Why haven't Smart Zone enabled DFS support for Israel AP Zones?Customer EnvironmentSmart Zone 5.2.2.0.1563 or earlier, 6.0.0, 6.1.0 versionRoot CauseIsrael DFS...
Random APs are frequently changing vSZ nodes
Recently noticed a recurring issue where numerous Access Points were experiencing random disconnections from the control interface of the vSZ-H. The state of these APs frequently involves disconnection and hopping across nodes. Refer to the checklist...
Ahamed1 by RUCKUS Team Member
  • 2718 Views
  • 0 replies
