Self-Help Articles
ICX keeps asking for password even after password reset.
Whenever an ICX is stuck in password prompt and the given procedure on article How to recover from a lost password ICX switches https://community.ruckuswireless.com/t5/RUCKUS-Self-Help/How-to-recover-from-a-lost-password-ICX-switches/m-p/52396#M74 do...
jeisson_diaz_0-1700154570793.png jeisson_diaz_1-1700154613869.png jeisson_diaz_0-1700153781316.png jeisson_diaz_2-1700154248148.png
How to fix Boot-monitor version mismatch error
When you upgrade from a Pre-08.0.90 Non-UFI image Version to 08.0.90 UFI image Version or newer versions, you might encounter a boot-monitor version mismatch error message. The show version command might also display a boot code mismatch message afte...
jeisson_diaz_0-1700079743641.png jeisson_diaz_1-1700079743643.png jeisson_diaz_2-1700079743644.png jeisson_diaz_3-1700079743653.png
Not able to migrate vSZ from ESXi 6.5 to 6.7 using vMotion
As a Ruckus Technical Support Engineer, I would like to share my experience here on how migration of vSZ works when done using vMotionCustomer EnvironmentvSZ running on 3.6.2.0.222 loaded in ESXi 6.5SymptomsAll the APs connected to the vSZ are gettin...
Message “no matching key exchange method found” when a outbound SSH connection is made from switches
The problem noticed is that the user will notice error message “no matching key exchange method found” when we to do an outbound SSH connection from other switch models in version 8095:Issue noticed:Sep 29 14:45:09:I:sshd: Unable to negotiate with 10...
Chandini by RUCKUS Team Member
  • 2715 Views
  • 0 replies
