Self-Help Articles
Adding an unleashed system ID to Unleashed Multi-site Manager
If you want to add an unleashed system ID to UMM, the first thing you need to do is verify that you have an active license for that system from UMM, go to UMM dashboard > Administration > License if you need to upload a license please select this opt...
aalvarez6 by RUCKUS Team Member
  • 2143 Views
  • 0 replies
Minimum Code Level to Onboard Cloud ICX Switch
Hey all,  I wanted to take a moment to touch on the minimum code level to onboard an ICX switch to RUCKUS Cloud. In order for an ICX to begin the onboarding process to RUCKUS Cloud, they must be running a minimum code level of 8090d. To confirm your ...
BenBeck by Moderator
  • 1984 Views
  • 0 replies
How to autofill a voucher code from SMS in iOS ?
SummaryThe auto-fill option allows a user to seamlessly and accurately apply a voucher code, or any such one-time-use codes. We can implement this very convenient feature for voucher code entry on CloudPath. StepsA small edit to the HTML source code ...
James_0-1681289466182.jpeg James_1-1681289506428.jpeg James_2-1681289564691.jpeg James_6-1681289732297.png
James by RUCKUS Team Member
  • 2115 Views
  • 0 replies
  • 2 kudos
