Self-Help Articles
Logging to the switch using CLI when you don’t have access to the switch and switch is up in cloud
This article will help you with logging into the switch through CLI using password through SSH/console when you are not able access the switch using the current password and switch is up in cloud R1Step 1: Click on “Venue “ Click on the Venue your sw...
Chandini_1-1683378883206.png Chandini_2-1683378933591.png Chandini_3-1683378982564.png Chandini_4-1683379014752.png
Chandini by RUCKUS Team Member
  • 3102 Views
  • 0 replies
  • 3 kudos
How to upgrade from older firmware versions to a UFI image?
If your firmware of the switch is in older versions before 8080 then you need to follow the below path. Here we are taking example of 7150 switch and are trying to upgrade from 8060 version to 8095g. Path to follow: 8060 -> 8080f non UFI -> 8095g UFI...
Chandini_0-1683377046581.png Chandini_1-1683377083622.png Chandini_2-1683377083625.png Chandini_3-1683377083626.png
  • 2781 Views
  • 0 replies
Ruckus Cloud API - Authentication Using JWT
Ruckus Cloud has now started to use JSON Web Tokens (JWT) to secure all endpoints. Previously Ruckus Cloud used a cookie with an API key for authentication in evey API call.•POST /token is used to obtain a jwt.•The response includes the tenantId and ...
ganesh_balarama_0-1682945338799.png ganesh_balarama_1-1682945841740.png ganesh_balarama_2-1682945958191.png
