Self-Help Articles
How to set up remote access using PFsense Radius authentication
Configure Radius parameters in the switch :Configure PFsense NAS informationGo to Services -> Free Radius -> NAS/Clients -> +Add  ( enter Switch Ip address, radius secret key,  Switch hostname)Configure User informationGo to User tab -> Add
avega_0-1676650989349.png avega_6-1676651060098.png avega_7-1676651090438.png avega_8-1676651119121.png
avega by RUCKUS Team Member
  • 3862 Views
  • 0 replies
  • 2 kudos
Where can I find the list of Temperature Grade 10G SFP modules Certified by Ruckus for Outdoor APs ?
Following  are the Ruckus Certified Temperature Grade 10G SFP+ Modules for Outdoor AP deployment.For the SR-Short Range Deployments (0-300 Meters): 10G-SFPP-USR 10GBASE-USR, SFP+ optic (LC), target range 100m over MMF10G-SFPP-USR-SA 10GBASE-USR, SFP+...
How to retrieve logs from client side cloudpath application
The Cloudpath application on the client device does have troubleshooting capabilities in it.Use the “Show Log” in the Cloudpath application to provide you with more details about any issues that the user is experiencing while enrolling in the device ...
basavaraj_linga_0-1674822448872.png basavaraj_linga_1-1674826238313.png basavaraj_linga_0-1674826097502.png basavaraj_linga_3-1674822448915.png
Basav by Moderator
  • 2367 Views
  • 0 replies
  • 3 kudos
Cloudpath Enrollment System bulk DPSK creation using excel
Many of Cloudpath customer request for option to create DPSKs in bulk, currently Cloudpath enrollment system does not give an option to create multiple DPSK altogether or via file upload from the DPSK pool setting, this article explains a workaround ...
vijaykuniyal_0-1674760960152.jpeg vijaykuniyal_1-1674760960155.jpeg vijaykuniyal_2-1674760960155.jpeg vijaykuniyal_3-1674760960156.jpeg
Cloudpath Enrollment System SCEP integration with JAMF
This article explains setting up a Cloudpath Enrollment System SCEP integration with JAMF for Apple device management.Table of ContentsCloudpath ConfigurationJAMF Configuration>CONFIGURATION PROFILE>SCEP SETTING>CERTIFICATE SETTING>NETWORK SETTINGNOT...
vijaykuniyal_0-1674685542461.png vijaykuniyal_1-1674685542473.jpeg vijaykuniyal_2-1674685542482.jpeg vijaykuniyal_3-1674685542486.jpeg
How to recover from a lost password ICX switches
Here is a basic guide on how to recover from a lost password ICX:Recovery from a lost password requires direct access to the serial port and a system reset.Start a CLI session over the serial interface to the RUCKUS ICX device.Reboot the device.While...
aalvarez6 by RUCKUS Team Member
  • 21148 Views
  • 0 replies
  • 8 kudos
