Self-Help Articles
How to deploy a DCHP server on Windows server 2012
This information pertains to general knowledge for utilization within the context of ICX-Unleashed-SZ-vSZ. Initially, need to connect with the Server Manager. Subsequently, we will install the DHCP feature. The installation choices are discretionary;...
Vsquez_Fer_0-1693500396845.png Vsquez_Fer_1-1693500396852.png Vsquez_Fer_2-1693500396857.png Vsquez_Fer_3-1693500396861.png
How to disable weak SSH chipper and CBC on the ICX switches
Here the switch model used is 7150 series and firmware running are 8095c.Run “show ip ssh config” to view all SSH details.Device#show ip ssh configSSH server                 : EnabledSSH port                   : tcp\22Host Key                   : RSA...
Chandini by RUCKUS Team Member
  • 8934 Views
  • 4 replies
  • 0 kudos
ICX XSS and CSRF Vulnerability
This is vulnerability in the web-based management interface of the ICX ruckus product.Workaround:Need to disable web management access to the switches using below options.By default, you will see https enabled.Device#show webHTTP server status: Disab...
  • 1605 Views
  • 0 replies
  • 0 kudos
Resolved! Facebook login not working in Unleashed Mobile app
Issue:On the Unleashed app, if we click on Manage Network >> and select Facebook, the authentication fails with the following error message:"Feature Unavailable: Facebook Login is currently unavailable for this app, since we are updating additional d...
iOS mobile app unable to login to manage Unleashed network.
Issue:When iOS mobile users tries to login to Unleashed app using the admin credentials, the authentication gets failed with the error "You are not connected to Unleashed Network.  Go to Settings"This issue is affected for iOS devices only, Android a...
sanjay_kumar_0-1692729203344.png sanjay_kumar_4-1692730114961.png sanjay_kumar_3-1692730086943.png
