Self-Help Articles
How to locate SWITCH password in Ruckus Cloud controller
Here is a quick guide on how to obtain the switch password in the ruckus cloud controller:- Go to the venue where the switch is located -Select configuration-Select switch configuration-Select AAA-Scroll down to local users - click in the eye to see ...
aalvarez6_2-1692289962434.png aalvarez6_0-1692289757587.png aalvarez6_1-1692289778451.png
aalvarez6 by RUCKUS Team Member
  • 2585 Views
  • 0 replies
  • 5 kudos
How the APs discover the IP address of the controller?
How Standalone APs Learn Controller AddressesIf your APs will be managed by a controller, you will need some way to ensure that the APs can discover the controller on the network. There are several different ways to do this, and the specific controll...
Multi-port AP not negotiating link speeds above 1000 Mbps.
Issue observed: APs with more than one ethernet port where the second port is capable of providing higher speeds (above 1000 Mbps) is unable to negotiate over 1000 Mbps speed with its uplink switch.Prerequisite: Switch should also be capable of provi...
James by RUCKUS Team Member
  • 2068 Views
  • 0 replies
How to troubleshoot DHCP address leasing issues
In an network, issues that are seen generally  >  End devices don’t or are unable to get an IP.>  End devices get an IP but are not able to reach out to internet.Here, will be looking into the first one : End devices don’t or are unable to get an IP....
jdryan by Moderator
  • 2324 Views
  • 0 replies
  • 0 kudos
v/SZ- "Upgrade Fail: Unsupported version"
Attempting to upgrade to the newest SmartZone versions may result in an error saying "Upload image failed. Unsupported version."This could happen if the current version of the controller is too old, so a 2-step upgrade may be required.Refer to the ta...
