Self-Help Articles
How to Disable LED Indicators in Ruckus Unleashed
In some situations, administrators may wish to disable the LED lights on the access points to avoid drawing attention to them, when installed in a public location, for example.To disable status LEDs on all APs of a specific model:Go to Access Points ...
v/SZ - What is the Application Signature Package or "sigpack"
What is the application signature package? It’s a file that helps the Access Points identify applications used on the internet. It’s mostly for security purposes when specific firewall policies are configured. It also helps keep track of the applicat...
How to troubleshoot DHCP issues on Ruckus ICX switch
Basic troubleshoot steps:[+] Always collect the packet capture to verify the DORA process[+] If the problem started after upgrade or downgrade - reconfigure DHCP on ICX device.Check if any difference in commands in previous version to new version[+] ...
va10461 by RUCKUS Team Member
  • 5774 Views
  • 0 replies
  • 0 kudos
Ruckus AP LED indicator meaning
In this article, we will delve into the meaning behind these LED indicators and explain the behaviors they may exhibit. The LED lights on Ruckus access points (APs) play an important role in providing information about the AP's current status. Whethe...
