Self-Help Articles
How to configure Breakout ports on ICX7850
This is an example how to configure breakout ports on ICX7850,  which is similar to other ICX models, however it might change the ports available per each ICX Model (7750,7550) Breakout mode is when a high-speed interface, for example 40 or 100g port...
avega_0-1689614913922.png avega_1-1689614913925.png avega_2-1689614913926.png
avega by RUCKUS Team Member
  • 2721 Views
  • 0 replies
  • 3 kudos
Need an FTP server? | How to use Mobaxterm as FTP server?
FTP is generally faster than TFTP. FTP uses TCP (Transmission Control Protocol) for data transmission, which provides error checking and correction, ensuring that the entire file is correctly received. This makes FTP more reliable and faster for tran...
Orlando_Elias_0-1689274201913.png Orlando_Elias_1-1689274355281.png Orlando_Elias_2-1689274500859.png
How to test SNMP version 3 using MobaXterm
This is a simple example how to configure SNMP version 3 with an ICX switch, please consider SNMP version 3 is more complex than versions 1 and 2, therefore, it might require additional configurations that we are not including in this articleICX conf...
