Self-Help Articles
Cloudpath Persistent XSS and CSRF Vulnerability
Hello All, This is an important security announcement for Cloudpath.What is the issue?A vulnerability in the web-based interface of the RUCKUS Cloudpath product could allow a remote, unauthenticated attacker to execute persistent XSS and CSRF attacks...
Debugs logs, show commands need to be collected for ICX-SZ issues
Testing Topology1. ICX switch connected to the SZ.Debugs and FITRACESExecute the below commands to clear the existing counters before enabling debug/fitrace.• clear ip revssh counters authentication• clear ip revssh counters channel all• clear ip rev...
va10461 by RUCKUS Team Member
  • 4664 Views
  • 0 replies
How to make an API call to Ruckus One
 Ruckus One uses JSON Web Tokens (JWT) to secure all endpoints.POST method is used to obtain a jwt.The API response to POST call includes tenantId and token.Token is valid for 60 minutes.POSTMAN:Postman is the tool used in this example to make an API...
MA by RUCKUS Team Member
  • 3316 Views
  • 0 replies
  • 3 kudos
Unable to view Fanless option is 8200 running version 10.0.00
Issue noticed:Device(config)#chassis  name        Chassis name  poll-time   Change hardware sensors polling interval seconds  trap-log    Change fan or power supply loggingOptions are not available to enable Fanless mode on 8200 switches.Solution: Fa...
Chandini by RUCKUS Team Member
  • 1859 Views
  • 0 replies
  • 0 kudos
How to enable Dynamic PoE power on the ICX switches:
The power management on the ICX switches until version 9010 have Static Power Management only where we have inline power enabled on the interface by default. Dynamic Power management helps with dynamic power allocation on the ports based on power con...
  • 11615 Views
  • 0 replies
  • 2 kudos
