Unleashed: How to limit GuestPass generation using Active Directory Group
vijaykuniyal
RUCKUS Team Member
This article explains setting up a Ruckus Unleashed with Active Directory Group for limiting users to create GuestPass.
Table of Contents
  • AD Configuration
  • Unleashed Configuration
Note: We are assuming Customer have knowledge and understanding of Active Directory.
Verified Unleashed Version: 200.12, 200.14
AD Configuration
Create a User Group in Active Directory User and Computer (If desired group is already created, entire AD Configuration step can be skipped)
  • Open Active Directory User and Computer from the Windows search.
  • once open Right Click on Users>>>New>>>Group
  • Name the Group as required.
  • Once Group is created, Right Click on Group>>>>Select Properties.
  • Click on Members>>>Add.
    search for user from AD users, which is allowed to create GuestPass (in this example I am searching for my user)
  • Enter the Name in the box >>> Click on Check Name.
  • Select the name required and Click OK.
  • Name will appear in the members.
  • Login to unleashed GUI from any browser and Select Admin and Services.
  • Select System>>>Roles>>>Create
  • Update the details as mentioned below.
    1: Name - As required.
    2: Description - As required.
    3: Group Attribute - Same as AD Group(GuestPass in our example)
    4: Select Specify WLAN  access
    5: Select the GuestPass SSID. (assuming its already created under Wi-Fi Networks)
    6: Tick the checkbox for Allow guest pass generation.
    and Click OK
  • Select Default Role and Click Edit.
  • Uncheck Allow guest pass generation and Click OK.
  • Select Services >>> AAA servers.
    2: Server Address - As required.
    3: Port - 389
    4: Windows Domain Name - Actual AD domain name.
  • Select Services >>> Guest Access Service>>>Guest Pass Generation>>>Authentication Server >>> Windows AD
    and Click Apply.
Once done only users from the defined AD group will be able to create Guestpass.
Vijay Kuniyal
Staff Technical Support Engineer
CCNA RnS | CCNA Wireless | RASZA | Meraki CMNO | RACPA
0 REPLIES 0
