06-27-2023 11:47 AM - edited 02-02-2024 08:57 AM
Hello All,
In this article we are going to share information about ports, which should be open on firewall for RUCKUS Access Points, Switches and other services/server to v/SmartZone communication.
For each major release port requirement may differ, so it is advised to refer the Administrator guide of respective release.
Refer the below documents major release wise.
If your controller is running on 6.1.0 or later version, you can also go to "Network > Data and Control Plane > Cluster", select any of the controller nodes from the left side pan, then click on the "Network Settings" under "Details" section. It lists up all the required ports under "Inbound ports'
For exact release related information, please go to v/SmartZone documentation at our support site and refer the administrator guide for your specific v/SmartZone version.
