06-30-2023 08:49 AM
Switch models used:
Versions tested:
Observation is that when the traffic is low in InOctet and OutOctet counters for Counter 64 and Counter32 values are correct but when it reaches 10 digits and above for Counter32 and Counter64 values are not correct
In Counter 32 it is not staying constant at its max value but varies where traffic is high
In counter 64 we see the 11th digit but looks restricted to only 10 digits, we will be unable to see it go above 10 digits.
Below are the Lab test results:
For 7850:
Switch Logs:
ICX7850-48FS Router# show statistics e 1/1/2
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/2 Up Forward Full 1G None No 1 0 d4c1.9e1b.48d7
Port 1/1/2 Counters:
InOctets 51435228692 OutOctets 51522876288
InPkts 803671229 OutPkts 805040568
ICX7850-48FS Router# show statistics e 1/1/3
1/1/3 Up Forward Full 1G None No 1 0 d4c1.9e1b.48d7
Port 1/1/3 Counters:
InOctets 51432024836 OutOctets 51525401610
InPkts 803624357 OutPkts 805080054
From the SNMP test :
snmpwalk -v2c -c public 10.177.95.135 1.3.6.1.2.1.2.2.1.10
IF-MIB::ifInOctets.1 = Counter32: 0
IF-MIB::ifInOctets.2 = Counter32: 4190588578
IF-MIB::ifInOctets.3 = Counter32: 4187384580
IF-MIB::ifInOctets.4 = Counter32: 0
IF-MIB::ifInOctets.5 = Counter32: 0
snmpwalk -v2c -c public 10.177.95.135 1.3.6.1.2.1.2.2.1.16
IF-MIB::ifOutOctets.1 = Counter32: 0
IF-MIB::ifOutOctets.2 = Counter32: 4278236322
IF-MIB::ifOutOctets.3 = Counter32: 4280761354
IF-MIB::ifOutOctets.4 = Counter32: 0
IF-MIB::ifOutOctets.5 = Counter32: 0
snmpwalk -v2c -c public 10.177.95.135 1.3.6.1.2.1.31.1.1.1.6
IF-MIB::ifHCInOctets.1 = Counter64: 0
IF-MIB::ifHCInOctets.2 = Counter64: 4190588720
IF-MIB::ifHCInOctets.3 = Counter64: 4187384580
IF-MIB::ifHCInOctets.4 = Counter64: 0
IF-MIB::ifHCInOctets.5 = Counter64: 0
snmpwalk -v2c -c public 10.177.95.135 1.3.6.1.2.1.31.1.1.1.10
IF-MIB::ifHCOutOctets.1 = Counter64: 0
IF-MIB::ifHCOutOctets.2 = Counter64: 4278236322
IF-MIB::ifHCOutOctets.3 = Counter64: 4280761354
IF-MIB::ifHCOutOctets.4 = Counter64: 0
IF-MIB::ifHCOutOctets.5 = Counter64: 0
IF-MIB::ifHCOutOctets.6 = Counter64: 0
IF-MIB::ifHCOutOctets.7 = Counter64: 0
For 7650:
Switch Logs:
ICX7650-48F Router(config)#show stat e 1/1/2
1/1/2 Up Forward Full 1G None No 1 0 d4c1.9e14.8f87
InOctets 11820437309 OutOctets 11757867978
InPkts 184690955 OutPkts 183713427
ICX7650-48F Router(config)#show stat e 1/1/3
1/1/3 Up Forward Full 1G None No 1 0 d4c1.9e14.8f87
InOctets 11819672892 OutOctets 11757732552
InPkts 184682313 OutPkts 183714498
From the SNMP test:
snmpwalk -v2c -c public 10.177.95.124 1.3.6.1.2.1.2.2.1.10
IF-MIB::ifInOctets.2 = Counter32: 3230499817
IF-MIB::ifInOctets.3 = Counter32: 3229737430
snmpwalk -v2c -c public 10.177.95.124 1.3.6.1.2.1.2.2.1.16
IF-MIB::ifOutOctets.2 = Counter32: 3167933670
IF-MIB::ifOutOctets.3 = Counter32: 3167797960
snmpwalk -v2c -c public 10.177.95.124 1.3.6.1.2.1.31.1.1.1.6
IF-MIB::ifHCInOctets.2 = Counter64: 3230503152
IF-MIB::ifHCInOctets.3 = Counter64: 3229738300
snmpwalk -v2c -c public 10.177.95.124 1.3.6.1.2.1.31.1.1.1.10
IF-MIB::ifHCOutOctets.2 = Counter64: 3167933670
IF-MIB::ifHCOutOctets.3 = Counter64: 3167797960
From 7750 Switch:
ICX7750-48F, 08.0.30a:
IF-MIB::ifInOctets.1 = Counter32: 2586343260
IF-MIB::ifHCInOctets.1 = Counter64: 10555524666401580
IF-MIB::ifOutOctets.1 = Counter32: 4258849576
IF-MIB::ifHCOutOctets.1 = Counter64: 11367708949537947
Port 1/1/1 Counters:
InOctets 10555524717470083 OutOctets 11367708953040734
InPkts 10937635334137 OutPkts 11431983718176
The counter64 values should look like output for 7750 switches but in version 9010 and 10.0.0 we see only 10 digits display.
Solution: Patch will be released in 9010g and 10.0.10b version and defect is logged under ID: FI-272681
