08-29-2023 10:54 AM
Here the switch model used is 7150 series and firmware running are 8095c.
Run “show ip ssh config” to view all SSH details.
Device#show ip ssh config
SSH server : Enabled
SSH port : tcp\22
Host Key : RSA 2048
Encryption : aes256-cbc, aes192-cbc, aes128-cbc, aes256-ctr, aes192-ctr, aes128-ctr, 3des-cbc
Permit empty password : No
Authentication methods : Password, Public-key, Interactive
Authentication retries : 3
Login timeout (seconds) : 120
Idle timeout (minutes) : 5
SCP : Enabled
SSH IPv4 clients : All
SSH IPv6 clients : All
SSH IPv4 access-group :
SSH IPv6 access-group :
SSH Client Keys :
Client Rekey : 0 Minute, 0 KB
Server Rekey : 0 Minute, 0 KB
To disable weak SSH cipher:
The diffie-hellman-group1-sha1 key exchange method is a weaker algorithm and can be disabled using the “no ip ssh key-exchange-method dh-group1-sha1” command.
Command:
To disable CBC encryption mode:
Command:
Output after disabling CBC encryption mode:
ICX7150-24F Switch(config)#show ip ssh config
SSH port : tcp\22
Host Key : RSA 2048
Encryption : aes256-ctr, aes192-ctr, aes128-ctr
SCP : Enabled
SSH Client Keys :
Reference links below:
Enabling SSH
Viewing SSH
Disabling telnet Access
Disable CBC
Disable weak SSH cipher:
06-17-2024 08:36 AM
Thanks, but how do you enable a stronger exchange method?
06-17-2024 08:00 PM
most likely by first switching to a recent os version. 10.0.20 supports most current encryptio & key exchange options - which supports the following:
SSH@campus-core(config)#ip ssh key-exchange-method
ASCII string Enter algorithms separated by a space:
diffie-hellman-group-exchange-sha256
diffie-hellman-group14-sha256
diffie-hellman-group16-sha512
diffie-hellman-group18-sha512
[email protected]
diffie-hellman-group14-sha1
ecdh-sha2-nistp256
ecdh-sha2-nistp384
ecdh-sha2-nistp521
curve25519-sha256
SSH@campus-core(config)#ip ssh ho
host-key-method SSH host key method
SSH@campus-core(config)#ip ssh host-key-method
ecdsa-sha2-nistp256
ecdsa-sha2-nistp384
ecdsa-sha2-nistp521
rsa-sha2-512
rsa-sha2-256
ssh-ed25519
ssh-rsa
SSH@campus-core(config)#ip ssh enc
encryption SSH encryption algorithm support
SSH@campus-core(config)#ip ssh encryption
aes256-cbc
aes192-cbc
aes128-cbc
aes256-ctr
aes192-ctr
aes128-ctr
3des-cbc
06-18-2024 08:08 AM
Thanks, not sure if the 7250, 7150 and 7450 would a recent OS version other than 8095. Do you happen to have the command to enable a stronger exchange for this version.
06-19-2024 04:47 PM
i don't think it's possible to enable more recent ssh ciphers on 809, but most of your devices seem to support at least 09.0.10 , which seems to support more recent options.
see 09.0.10j_cd2 release notes.
