How to disable weak SSH chipper and CBC on the ICX switches
Chandini
RUCKUS Team Member
Here the switch model used is 7150 series and firmware running are 8095c.
Run “show ip ssh config” to view all SSH details.
Device#show ip ssh config
SSH server                 : Enabled
SSH port                   : tcp\22
Host Key                   : RSA 2048
Encryption                 : aes256-cbc, aes192-cbc, aes128-cbc, aes256-ctr, aes192-ctr, aes128-ctr, 3des-cbc
Permit empty password      : No
Authentication methods     : Password, Public-key, Interactive
Authentication retries     : 3
Login timeout (seconds)    : 120
Idle timeout (minutes)     : 5
SCP                        : Enabled
SSH IPv4 clients           : All
SSH IPv6 clients           : All
SSH IPv4 access-group      :
SSH IPv6 access-group      :
SSH Client Keys            :
Client Rekey               : 0 Minute, 0 KB
Server Rekey               : 0 Minute, 0 KB
To disable weak SSH cipher:
The diffie-hellman-group1-sha1 key exchange method is a weaker algorithm and can be disabled using the “no ip ssh key-exchange-method dh-group1-sha1” command.
Command:
  • Device(config)#no ip ssh key-exchange-method dh-group1-sha1
To disable CBC encryption mode:
Command:
  • Device(config)# ip ssh encryption disable-aes-cbc
Output after disabling CBC encryption mode:
ICX7150-24F Switch(config)#show ip ssh config
SSH port                   : tcp\22
Host Key                   : RSA 2048
Encryption                 : aes256-ctr, aes192-ctr, aes128-ctr
SCP                        : Enabled
SSH Client Keys            :
Reference links below:
Enabling SSH
Viewing SSH
Disabling telnet Access
Disable CBC
Disable weak SSH cipher:
0 REPLIES 0
