Unable to change SSH port number from port 22 on ICX switches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-30-2023 08:33 AM
Error encountered below:
ICX8200-24 Router(config)#ip ssh port 2300
Close all current SSH connections, then try again
From Debugs we see below details :
[U1][3][Apr 4 19:15:00.018][sshm][Debug][11916806089001951530] SSH_SUCC[12]: Outgoing_Connection_ESTABLISHED
[U1][3][Apr 4 19:15:00.018][sshm][Debug][11916806089001951530] SSH[12]: session state: Init
[U1][3][Apr 4 19:20:00.017][sshm][Debug][11916806089001951530] SSH_SUCC[11]: Outgoing_Connection_ESTABLISHED
[U1][3][Apr 4 19:20:00.017][sshm][Debug][11916806089001951530] SSH[11]: session state: Init
[U1][3][Apr 4 19:20:00.640][sshm][Debug][1155957247621203457] SSH[10]: RX Message TYPE[SSH_MSG_CHANNEL_OPEN], PKT_LEN[92], PAYLOAD_LEN[71]
[U1][3][Apr 4 19:20:00.702][sshm][Debug][11916806089001951530] SSH_SUCC[12]: Outgoing_Connection_ESTABLISHED
[U1][3][Apr 4 19:20:00.703][sshm][Debug][11916806089001951530] SSH[12]: session state: Init
[U1][3][Apr 4 19:20:16.598][sshm][Debug][1155975265009010177] SSH[10]: RX Message TYPE[SSH_MSG_CHANNEL_WINDOW_ADJUST], PKT_LEN[28], PAYLOAD_LEN[8]
The above SSH debugs show us that this occurs when the switch is connected to Smartzone.
From Lab test:
From Logs:
manager active-list 10.177.89.120
manager registrar
manager port-list 987
Config Status:Enabled Operation Status:Enabled
State:SSH CONNECTED Prev State:SSH CONNECTING Event:SZ_SSH_CONNECT_EVENT
SWR List : None
DNS List :
Active List : 10.177.89.120
Active List IPV6 : None
DHCP Option 43 : No
DHCP Opt 43 List : None
Backup List : None
Backup List IPV6 : None
Merged List : 10.177.89.120
SZ IP Used : 10.177.89.120
Port List : 987
Server Port Used : 443
SWR host : sw-registrar.ruckuswireless.com
SWR discovery retry cnt : 0
SWR host retry time : 15
Query Status : APPROVED
SSH Tunnel Status -:
Tunnel Status : Established
SSH Port : 22
CLI IP/Port : 127.255.255.253/43894
SNMP IP/Port : 127.255.255.254/10092
Syslog IP/Port : 127.0.0.1/20514
HTTP CLIENT IP/Port : 127.0.0.1/5080
HTTP SERVER IP/Port : 127.255.255.252/53556
Timer Status : Not Running
After Removing SZ config:
ICX8200-24 Router(config)#no manager active-list 10.177.89.120
ICX8200-24 Router(config)#show sz status
============ MGMT Agent State Info ===================
Config Status:Enabled Operation Status:Disabled
State:DISABLED Prev State:QUERY Event:SZ_EVENT_NONE
SWR List : None
DNS List :
Active List : None
DHCP Option 43 : No
Backup List : None
Merged List :
SZ IP Used :
Port List : 987
Query Status : Not Initiated
Tunnel Status : Not Initiated
SSH Port : 22
CLI IP/Port : None/None
SNMP IP/Port : None/None
Syslog IP/Port : None/None
HTTP CLIENT IP/Port : None/None
HTTP SERVER IP/Port : None/None
Solution:
- Remove active list using command " no manager active-list <ip address> "
- Check "show sz status" and make sure sz is disconnected
- Run "ip ssh port 2300" and enter
- Enable the sz connection once port number is changed
Other solutions:
- Run “manager disable”. This will bring the ssh connection down and switch will be down in SmartZone and state in the "Show sz status " will be disabled
- Even when switch is not connected to Smartzone you will be able to change the SSH port number in the switch
- Labels:
