08-29-2023 10:48 AM - edited 08-29-2023 10:49 AM
This is vulnerability in the web-based management interface of the ICX ruckus product.
Workaround:
Need to disable web management access to the switches using below options.
By default, you will see https enabled.
Device#show web
HTTP server status: Disabled
HTTPS server status: Enabled
No web connection.
Use the below command to disable https:
Device(config)#no web-management https
If http is also enabled, then use the below command:
This vulnerability is found on 8095k and lower versions.
Resolution: If major release on switch is 8095 version, then Upgrade to FI 08.0.95m or later
This vulnerability is also resolved on ICX switches on upgrading to 9010a and above.
Reference link for more details on the vulnerability:
