08-29-2023 10:54 AM
Here the switch model used is 7150 series and firmware running are 8095c.
Run “show ip ssh config” to view all SSH details.
Device#show ip ssh config
SSH server : Enabled
SSH port : tcp\22
Host Key : RSA 2048
Encryption : aes256-cbc, aes192-cbc, aes128-cbc, aes256-ctr, aes192-ctr, aes128-ctr, 3des-cbc
Permit empty password : No
Authentication methods : Password, Public-key, Interactive
Authentication retries : 3
Login timeout (seconds) : 120
Idle timeout (minutes) : 5
SCP : Enabled
SSH IPv4 clients : All
SSH IPv6 clients : All
SSH IPv4 access-group :
SSH IPv6 access-group :
SSH Client Keys :
Client Rekey : 0 Minute, 0 KB
Server Rekey : 0 Minute, 0 KB
To disable weak SSH cipher:
The diffie-hellman-group1-sha1 key exchange method is a weaker algorithm and can be disabled using the “no ip ssh key-exchange-method dh-group1-sha1” command.
Command:
To disable CBC encryption mode:
Command:
Output after disabling CBC encryption mode:
ICX7150-24F Switch(config)#show ip ssh config
SSH port : tcp\22
Host Key : RSA 2048
Encryption : aes256-ctr, aes192-ctr, aes128-ctr
SCP : Enabled
SSH Client Keys :
Reference links below:
Enabling SSH
Viewing SSH
Disabling telnet Access
Disable CBC
Disable weak SSH cipher:
