02-29-2024 08:47 AM
Behavior noticed:
ICX7850-48F Router(config)#interface eth 1/1/1
ICX7850-48F Router(config-if-e25000-1/1/1)#speed-duplex 10g-full
This speed is not allowed on port 1/1/1 due to quad portgroup speed restriction(portgroup: 1/1/1 to 1/1/4)
ICX7850-48F Router(config-if-e25000-1/1/1)#end
Applicable ICX switch model:
If the switches are running version 8095 and below, then the below details will help you configure the quad port setting:
If the switches are running version 8095 and below, then there is a workaround which will help you set individual ports to 10g or 1g.
Example:
In this case switch is running 8095m version
ICX7850-48F Router(config)#int e 1/1/9 to 1/1/12
ICX7850-48F Router(config-mif-1/1/9-1/1/12)#speed-duplex 10g-full
ICX7850-48F Router(config-mif-1/1/9-1/1/12)#exit
ICX7850-48F Router(config-if-e25000-1/1/9)#speed-duplex 1000-full
ICX7850-48F Router(config-if-e25000-1/1/9)#exit
From running configuration 8095m
interface ethernet 1/1/9
interface ethernet 1/1/10
speed-duplex 10G-full
interface ethernet 1/1/11
interface ethernet 1/1/12
Port speed for port groups, cannot be changed individually. If required, the speed must be changed to all ports in the same quad-group and then we would be able to change speed to 1g on individual ports. This was a workaround in versions 8095 and below.
If the switches are running version 9010 and above versions, then the below details will help you configure the quad port setting:
If the switches are running version 9010 and above, then there is no workaround which will help change speed on interfaces. It is only considering four ports in group to be set to same speed.
Example:
In this case switch is running 10.0.10b version
ICX7850-48F Router(config)#int e 1/1/10
ICX7850-48F Router(config-if-e25000-1/1/10)#speed-duplex 1000-full
This speed is not allowed on port 1/1/10 due to quad portgroup speed restriction(portgroup: 1/1/9 to 1/1/12)
From versions 9010 and above in 7850-48F model speed settings is a design change to maintain consistency to the port group.
Details from documents:
Management guide for 8095 version:
Management guide for 9010 version:
