v/SZ - What is the Regular and non-Regular Application Signature Package?
Orlando_Elias
RUCKUS Team Member
Visit this post to understand what is the Application Signature Package.
Overview:
There are two types of Signature Packages (Sigpacks) available in the Support site for the v/SZ (virtual SmartZone) platform:
1. Regular Sigpack and
2. Non-Regular Sigpack.
These packages serve different purposes and are designed to be used in specific scenarios.
1. Regular Signature Package:
The Regular Sigpack is a comprehensive package that can be utilized in various scenarios. It is specifically required if you intend to make use of the Client Virtual Id Extraction feature within the WLAN configuration.
  • Compatibility: This package is not supported by 802.11ac Wave 1 AP running firmware prior to version 6.0.
2. Non-Regular Signature Package:
The Non-Regular Sigpack is a versatile package designed for use in scenarios other than those requiring the Client Virtual Id Extraction feature. It is compatible with any supported AP model and firmware version.
Note: Using the Non-Regular Sigpack will trigger a prompt indicating that the Regular Sigpack is available for download.
At Application Control > Application Signature Package, users can check the following information:
  • Current Signature Package Info:
    • Displays the file name and version of the currently installed package.
    • Indicates whether the current package is the Regular Sigpack.
  • Latest Available from Support Site:
    • Displays the latest available Sigpack on the Support site.
    • Indicates whether the Support Regular Sigpack is available for download.
Download here the latest Regular sigpack for 6.1.1
Download here the latest non-Regular sigpack for 6.1.1
With regards,
Orlando Elias
Technical Support
0 REPLIES 0
