08-29-2023
11:02 AM
- last edited on
08-31-2023
09:54 AM
by
Vásquez_Fer
Error encountered below:
Reason for getting the above error:
Hence if you need the switches to operate with PoE then you will need to retain 8095k. If you want to add these switches to the cloud, you need to wait for 9010h release for TI PoE chipset to work.
If you try adding switches with TI PoE issue to cloud, you will encounter below error messages.
How to identify the 7150-48ZP switches have new PoE chipset:
Check the MCU details of the switch using “dm hwinfo” command. These are mostly 2023 batches of switches which have new TI PoE chipset.
ICX7150-48ZP Switch#dm hwinfo
HW Ver: 3.1 [Production-2], Main board CPLD Rev: 0.4.a
Rear module card CPLD Rev: 0
Booted from: 1
Primary Uboot Failure Record: 0
Secondary Uboot Failure Record: 0
PoE hardware info:
Unit 1:PoE MCU: MSP430, PSE: TPS23881
Check for the PoE version and Hardware version using command “show PoE detail” when switch is on 8095k version, and you will see the below details.
Firmware
Version
01.56.1
Hardware
Version
V5R34
Device HW version : 0:V5R34 1:V5R34 2:V5R34 3:V5R34 4:V5R34 5:V5R34 6:V5R34 7:V5R34
Device Temperature(deg-C) : 0:32 1:36 2:34 3:30 4:30 5:26 6:34 7:30
Device Status : 0:Good 1:Good 2:Good 3:Good 4:Good 5:Good 6:Good 7:Good
Below are the error details you will notice related to PoE if the switch is running on 9010 version.
Switch firmware version 9010f with new TI PoE chipset:
Firmware
Version
00.0.0
Hardware
Version
UNKNOWN
Device HW version : 0:UNKNOWN 1:UNKNOWN 2:UNKNOWN 3:UNKNOWN 4:UNKNOWN 5:UNKNOWN 6:UNKNOWN 7:UNKNOWN
Device Temperature(deg-C) : 0:0 1:0 2:0 3:0 4:0 5:0 6:0 7:0
Device Status : 0:Failed 1:Failed 2:Failed 3:Failed 4:Failed 5:Failed 6:Failed 7:Failed
Log Size: 2000 entries. Number of entries in use: 2 for unit 1.
Log printing is requested for complete log.
|S.No.|Timestamp | Sys | Dev | Port | Event Trace Message |
1 | Fri Jun 9 06:53:54 | N | N/A | N/A | PoE Event Log Mgr: User Req Logging On
2 | Fri Jun 9 06:54:47 | Y | N/A | N/A | Loss of sync with controller in slot 1
After Rebooting the switch on 9010 version:
******* Starting HMON service for SNMPD *******
Jun 09 08:12:25:660838:info:fi_debug:debug_logs:1:4557112064: poeglue_i2c_read_boot: i2c read Failed:-4
Jun 09 08:12:25:970257:info:fi_debug:debug_logs:1:0: poeglue_proc_chassis_itc_msg: i2c write failed:-5
Jun 09 08:12:26:071219:info:fi_debug:debug_logs:1:15513810895616: poeglue_i2c_read: i2c read Failed:-4
Jun 09 08:12:26:812712:info:fi_debug:debug_logs:1:16312674812672: poeglue_i2c_read: i2c read Failed:-4
Jun 09 08:12:27:881837:info:fi_debug:debug_logs:1:17214617944832: poeglue_i2c_read: i2c read Failed:-4
Jun 09 08:12:29:029875:info:fi_debug:debug_logs:1:18099381207808: poeglue_i2c_read: i2c read Failed:-4
You will see above outputs for PoE on 9010f version.
Workaround:
Reference links:
TI PoE TSB referred:
