07-20-2022
06:44 AM
- last edited on
05-04-2026
10:10 AM
by
df_ruckus
How to perform Ruckus Cloud ICX VLAN port assignment through Switch Configuration profile?
Switch Configuration profiles allow you to define the VLANs for Switch models of your choice and Access Control Lists (ACLs). Once defined, these switch profiles can be applied to one or more venues. Any switch joining a venue will have the defined configuration applied automatically. You can create switch configuration profiles and attach these profiles to venues as required.
When a switch is registered on RUCKUS Cloud under this venue comes online, it inherits all the configuration from the profile. You can always override the configuration by editing the switch directly from Ruckus Cloud >> Network Devices >> Switches >> Click on the switch you wish to edit >> Edit Switch
Adding to this, we have also got a provision to configure the VLAN assignments on the port for the switches we add, provided the switches are brand new or factory defaulted.
To factory reset the switch:
ICX7150-24P Switch#erase system factory-default
System will go for reload after factory reset. Please enter 'y' to confirm, 'n' to exit :
(enter 'y' or 'n'): y
* Factory Reset Alert *
* Please pay attention to the details listed below *
* 1. uboot params will be erased, you might want to *
* backup the uboot params *
* stop at uboot and do 'printenv' to read uboot params *
* 2. All configuration will be erased, you might want to *
* backup the config *
* 3. Core Files, Logs will be erased *
* 4. SAU license will be restored to original SKU *
* use show license sau for more detials *
* 5. XML license will be erased *
I have read the alert and factory reset can be performed now.
(enter 'y' or 'n'):y
Once the switch comes online, it would fetch all the configuration from the profile
You can review the configuration management on an online switch from: Ruckus Cloud >> Network Devices >> Switches >> Click on the switch you wish to review >> Configuration Management >> History
Following is the configuration for VLAN 24 in switch configuration profile
Once the switch is Operational, we could see all the port assignments on the switch.
Further, any configuration change made will be pushed to respective switches:
The reason behind the VLAN port assignments specific to switches in Factory default state is that:
