How to enable Dynamic PoE power on the ICX switches:
Chandini
RUCKUS Team Member
The power management on the ICX switches until version 9010 have Static Power Management only where we have inline power enabled on the interface by default.
Dynamic Power management helps with dynamic power allocation on the ports based on power consumed by the end device connected to the switch.
Supported Models
  • ICX 7550
  • ICX 7650
  • ICX 8200
Supported version.
  • 10.0.10 and higher
Using Static Power Management on the Switch:
Command:
Ruckus(config)#inline power
Output:
Ruckus(config)#show poe
Power Capacity:         Total is 124000 mWatts. Current Free is 64000 mWatts.
Power Allocations: Requests Honored 8 times
 Port   Admin   Oper    ---Power(mWatts)---  PD Type  PD Class     Pri  Fault/
        State   State   Consumed  Allocated                             Error
  1/1/1 On      On          4733     30000   2P-IEEE  Class 4        3  n/a
  1/1/2 On      Off         6015     30000   2P-IEEE  Class 4        3  n/a
  1/1/3 On      Off            0         0   n/a      n/a            3  n/a
  1/1/4 On      Off            0         0   n/a      n/a            3  n/a
  1/1/5 On      Off            0         0   n/a      n/a            3  n/a
  1/1/6 On      Off            0         0   n/a      n/a            3  n/a
  1/1/7 On      Off            0         0   n/a      n/a            3  n/a
  1/1/8 On      Off            0         0   n/a      n/a            3  n/a
 Total                     10748     60000
Using Dynamic Power Management on the Switch:
Command and options:
Ruckus(config)#inline power allocation
  dynamic   Move from Static allocation to Consumption based Power allocation -
            CAUTION: PDs can get shutdown, make sure overall consumption
            doesn't exceed the budget
Ruckus(config)#inline power allocation dynamic
  ASCII string   all or unit-id list:  2,3,5-7,8 (no space)
Ruckus(config)#inline power allocation dynamic all
Output:
Power Capacity:         Total/Reserved/Unconsumed is 124.0/0.0/113.2 Watts.
  1/1/1 On      On          4733     30000*  2P-IEEE  Class 4        3  n/a
  1/1/2 On      Off         6015     30000*  2P-IEEE  Class 4        3  n/a
 Total                     10748     60000
(*) Allocated power being dynamically managed.
Using Dynamic Power Management on the Switch with Priority:
The devices which are mission critical Priority can be assigned to those end devices using below command.
Ruckus(config)#int e 1/1/1
Ruckus(config-if-e1000-1/1/1)#inline power priority
  DECIMAL   Priority value 1..3 (highest..lowest)
  <cr>
Ruckus(config-if-e1000-1/1/1)#inline power priority 1
Output:
  1/1/1 On      On          4733     30000*  2P-IEEE  Class 4        1  n/a
 Total                     10748     60000
Link referred:
0 REPLIES 0
