How to Disable LED Indicators in Ruckus Unleashed
MariaC862
In some situations, administrators may wish to disable the LED lights on the access points to avoid drawing attention to them, when installed in a public location, for example.
To disable status LEDs on all APs of a specific model:
  1. Go to Access Points > Summary > Edit > Other.
  2. Select the AP model from the list and enable the option Disable Status LEDs. The setting must be configured for each AP model individually.
  3. Click Finish to save your changes
For more info on the LED behavior meaning please visit: https://community.ruckuswireless.com/t5/RUCKUS-Self-Help/Ruckus-AP-LED-indicator-meaning/td-p/67848
Maria Cordoba
Sr. TSE | RICXI | RCNI
0 REPLIES 0
