12-01-2023 01:35 PM - edited 12-01-2023 01:37 PM
This guide will explain, in details, how to disable two parameters that will cause that your Sonos devices can't pair with each other.
Command |
Explanation |
set qos eth0 directed multicast disable
This prevents the WLAN from converting multicast traffic to unicast. |
qos directed-threshold 0 |
disable the multicast and broadcast threshold. |
— Requirements:
*SSH client access (Putty on Windows, macOS command Terminal, or Linux terminal).
*Download putty for Windows computer.
*For macOS, you will use the terminal app integrated into your MAC.
Enter the next command from the MAC terminal for SSH access
Format
ssh <unleashed user>@<IP of the master Access Point>
Example
*Or from Windows open Putty and add the next information, then hit open
Note: the credentials for the CLI access to the master Access Point are the same credentials you used for the APP or the Web GUI
1: Using your SSH client application such as a putty or MAC terminal, gain access via CLI to the AP Master Unleashed.
2: Now enter the credentials:
Enter the username and password
You should be at the command prompt
ruckus>
Enter the following command: enable
ruckus>enable
ruckus#
Enter the command: config
ruckus#config
ruckus(config)#
Enter the command: show wlan
ruckus(config)#show wlan
Enter the command: wlan home-WiFi
Replace home-WiFi with the name of your Wi-Fi SSID
ruckus(config)# wlan home-WiFi
ruckus(config-wlan)#
Enter the command: no qos directed-multicast
ruckus(config-wlan)# no qos directed-multicast
Enter the command: qos directed-threshold 0
ruckus(config-wlan)# qos directed-threshold 0
Enter the command: end
ruckus(config-wlan)# end
This will save the changes.
Now restart your SONOS components
