What code should I run on my ICX? Check the 'Recommended Firmware' field on the product support page
BenBeck
Hey All,
Have you ever wondered what code Ruckus recommends you run on your ICX? You are in luck. Each product support page has a built-in recommendation or recommendations. While these recommendations will not cover every scenario or customer, it should be your starting reference when selecting code for ICX devices. The recommendations are updated occasionally and will change over time. We recommend most customers look to our Stability Release if it contains all needed features for your network. As always, you can contact us if you are unsure where to start.
To find the recommended code, navigate to:
https://support.ruckuswireless.com/documents
From there, select the 'Choose a Product' dropdown, select your switch model.
I have attached a screenshot from our ICX7850 page highlighting the recommended code field. Clicking on the link will bring you directly to the software download page.
0 REPLIES 0
