03-22-2024 11:06 AM
When downgrading the switch from 9010 and above to 8095 “ve” related interface commands and L3 configuration would be removed
Issue noticed:
When the user chooses to downgrade from 9010 version and above to 8095 versions in ICX switches, they will notice that the “ve” commands and layer 3 related configurations within the “ve” are wiped out.
Lab output:
If the switch running 9010 version have the below configuration:
interface ve 1
ip address 1.1.1.1 255.255.255.0
no spanning-tree
interface ve 3
ip address 2.2.2.1 255.255.255.0
no spanning-tree
interface ve 5
ip address 3.3.3.1 255.255.255.0
no spanning-tree
When the customer would downgrade from 9010 and above to 8095 versions the configuration would be removed and any configurations included within the ve’s would also be removed.
Reason:
This is an expected behavior. The reason why this is noticed is because on 8095 versions, if we would have to configure “ve ” interface we use command “router-interface ve “ve ID””
Example:
device(config)# vlan 2
device(config-vlan-2)# untag ethernet 1 to 4
device(config-vlan-2)# router-interface ve 2
device(config-vlan-2)# interface ve 2
But from 9010 and above versions the “router-interface ve “ve ID”” command is deprecated and when a “vlan” is created a “ve” with same ID as vlan is also created.
Example:
Due to the above changes when you upgrade from 8095 version to 9010 version or above you would not see a problem but when you downgrade from 9010 version and above to 8095 you will notice that since the command “router-interface ve “ve ID”” is not appended to the running configuration the “ve” interface would be completely deleted.
It is recommended to save the configuration as a backup when downgraded from 9010 and above to 8095 and have sufficient downtime to revert back the configurations.
