12-26-2023 07:21 AM
Issue:
Command “aaa authentication login privilege-mode” was removed in 9010 and 10.0.00 versions.
This command was missing in certain 9010 and 10.0.0 versions. Below is the example the output looked like.
ICX7850-48FS Router(config)#aaa authentication login
default The default authentication list
In the above output it is noticed that privilege mode option is missing.
Solution:
This command was added back in version 9010h and below is a example from lab output where 7650 switch is running on 9010h version
ICX7650_test(config)#aaa authentication login
privilege-mode Take user to privilege mode after successful authentication
ICX7650_test(config)#aaa authentication login privilege-mode
For 8200 switches this command was added back in version 10.0.10b and above and below is an example
ICX8200_test(config)#aaa authentication login
If you are looking to enable privilege mode on the switch and switches are on 9010 and 10.0.00 versions then they would need a upgrade to 9010h and above or 10.0.10b and above.
07-10-2024 03:38 PM
side note: excluding 10.0.10d since it was removed by accident in that release.(issue FI-296313), but i guess it will return in the next version.
07-12-2024 09:21 AM
Hi Inphobia
Noted. Thanks
