12-11-2024 06:14 AM - edited 12-11-2024 06:19 AM
When dealing with a corrupted flash or related issues, follow these steps to troubleshoot and resolve the problem.
When a unit is stuck in a boot loop and fails to stabilize, the first step is to console into the unit directly and review the boot process. This can provide insights into why the unit is not booting correctly.
Booting image from Secondary
Wrong Image Format for bootm command
ERROR: can't get kernel image!
could not boot from secondary, no valid image; trying to boot from primary
Booting image from Primary
Ruckus Networks Bootloader: 10.1.26T215 (Nov 29 2022 - 04:42:59)
Validate Shmoo parameters stored in flash ..... OK
Restoring Shmoo parameters from flash .....
Running simple memory test ..... OK
ICX7450-24 Copper (Non-POE), PVT1
SYS CPLD VER: 0x10, Released Ver: 0
Enter 'b' to stop at boot monitor: 3 >>>> Press 'b' to stop the process.
ICX7450-Boot>
ICX7450-Boot> show_image
Primary : SPR08095k(33554432)
Secondary: SPS08095j(31457280)
Example:
ICX 7450-48> setenv serverip 10.10.10.21
ICX 7450-48> setenv ipaddr 10.10.10.22
ICX 7450-48> setenv gatewayip 10.10.10.1
ICX 7450-48> setenv netmask 255.255.255.0
ICX 7450-48> saveenv
ICX 7450-48> printenv
baudrate=9600
ipaddr=10.10.10.22
gatewayip=10.10.10.1
netmask=255.255.255.0
serverip=10.10.10.21
uboot=ruckus/ICX7450/bootcode/spz10115
Version:10.1.06T215 (May 15 2015 - 11:28:23)
ICX 7450-48> ping 10.10.10.21
ethPortNo = 0
Using egiga0 device
host 10.10.10.21 is alive
ICX 7450-48> setenv image_name images/ICX/SPR08090.bin
ICX 7450-48> update_primary
Provide the file name of the boot image to be copied from the tftp server.
ICX 7450-48> setenv uboot <xxx.bin>
ICX 7450-48> update_uboot
ICX 7450-48> boot_primary
Video Link as reference: https://www.youtube.com/watch?v=RHriOYYD_iI
Link as reference : https://docs.commscope.com/bundle/fastiron-09010-upgradeguide/page/GUID-9B5D5A56-039D-44FB-8FD2-B9B5...
boot_golden_primary - Flash the Golden UFI Image to Primary and boot from Primary
02-12-2025 06:58 PM
Still I am not able to connect to TFTP
ICX7150-Boot>printenv
baudrate=9600
ipaddr=10.10.10.22
uboot=brocade/ICX7150/bootcode/spz10106b002
image_name=SPS08090.bin
ver=10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Environment size: 212/16379 bytes
ICX7150-Boot>ping 10.10.10.21
bcm_xgs_gmac-0 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Auto-neg error, defaulting to 10BT/HD
Change GMAC speed to 10MB
Using bcm_xgs_gmac-0 device
ARP Retry count exceeded; starting again
ping failed; host 10.10.10.21 is not alive
ICX7150-Boot>
