12-08-2021 07:29 AM - edited 02-01-2024 12:29 PM
Hey all,
I want to take a look at building a stack from scratch. There are many ways to build, edit and manipulate stack units. Extensive details can be found in your respective stacking guide. In this example, I will be using 8095 software and that corresponding stacking guide can be found here. I will be taking three ICX7150s and stacking them together. I will show two methods: Stack Interactive-Setup and Zero-Touch Provisioning (ZTP). Stack Interactive-Setup is probably the most common method and allows for granular control of the stack formation by the user. ZTP generally yields results similar to stack-interactive setup when accepting all defaults. I should note ZTP requires clean (default configuration) units, while stack-interactive setup can deal with this scenario.
With both methods, I generally recommend the following prerequisites:
Building a stack via Stack Interactive-Setup
The first thing we want to do is enable stacking on our active unit:
ICX#conf t
ICX(config)#stack enable
Success - Enable stacking. This unit actively participates in stacking
Now let’s enter the interactive stack setup. We have multiple options here, but option 3 is the most versatile and we will use that:
ICX#stack interactive-setup
You can abort stack interactive-setup at any stage by <ctrl-c>
0: quit
1: change stack unit IDs
2: discover and convert new units (no startup-config flash) to members
3: discover and convert existing/new standalone units to members
2&3 can also find new links and auto-trunk or convert chain(s) to ring.
Please type your selection:3
The software will now probe all candidate stack ports and show you the stacking chain/ring that it has discovered. Once you accept the stacking topology by pressing ‘y’, you will also need to accept the proposed stacking IDs. You will be given a default option. In this case, it has proposed stack IDs 2 and 3. We can just hit ‘Enter’ on these lines and it will use the default proposals. The software will then show you a graphic depiction of how the stack will look should you use the selected options. The last portion of the interactive setup will ask you if you want to accept the given topology. If all looks well, go ahead and enter ‘y’ to proceed. For the sake of formatting, here is a screenshot showing this whole process:
At this time, the additional units will reload and join the stack. The time required will vary based on model, but once the new units have joined the stack, go ahead and issue a ‘show stack’ to confirm they have joined:
Take note of the ‘S’ and ‘D’ notations next to the units. These stand for Dynamic and Static. Dynamic units are newly added and that means we need to save our configuration! Go ahead and ‘wr mem’ and these will change to static:
ICX#conf t
Now let's go ahead and turn on the Zero-Touch Provisioning feature:
ICX(config)#stack zero-touch-enable
The software will now probe candidate stack ports, build a stacking topology and reload the new units into the stack. This process can take some time and will vary by model. For the sake of formatting, here is what the process would look like via a screenshot:
Once the new units have joined the stack, go ahead and issue a ‘show stack’ to confirm they have joined. Output should be the same as seen earlier in this post.
We now need to turn off the ZTP feature and save the configuration:
ICX(config)#no stack zero-touch-enable
ICX(config)#wr mem
That's it! Hopefully this post was helpful. Let me know if you have any questions/concerns.
12-09-2021 06:42 AM
Hey Ben,
What are the benefits of stacking using the interactive setup rather than the zero-touch?
12-09-2021 07:40 AM
Hey Blake,
ZTP is certainly an option. It generally will yield results that are the same as doing stack-interactive setup and just accepting all defaults. The downside being less control and the feature needs to be toggled on and off as it should not be enabled all the time. ZTP also requires the new stack members to be completely clean (default) configs while interactive setup can deal with this. With that said, it is a great feature and certainly warrants discussion here. Thanks for bringing it up. Maybe I will edit this post to include ZTP or possibly do a separate one. Stay tuned!
12-09-2021 08:28 AM
Hey Blake. I have added ZTP to the post. Thanks again for the input!
