08-05-2023 08:02 AM
After a power outage, my Ruckus router AIR light is not blinking and nor not on. The other lights from the router are on. I have tried numerous attempts to unplug, reset and even disconnect the router from the wall and connect it again. I cannot access my network name that was created for the access point, but i can access the Frontier router. How can I reconnect to my old router name? I am having trouble accessing unleashed as well.
I have a Ruckus R320 Series Unleashed
08-14-2023 11:35 AM
Hi @Ant
Please try to access the switch via console using the below guide and share the output of the following commands.
How to console in the ICX-7150-C12P:
Show flash
Show version
08-15-2023 01:55 PM
Hi @Ant
Please try to access the switch CLI using the IP address 192.168.254.12 in putty and let us know the result.
Once you are able to login to switch CLI please share the output of the following commands to check whether the switch is running the 8090+ later software version or not.
Show flash
Show version
08-15-2023 01:58 PM
it asking me to: Long In As: what do I login as?
08-15-2023 01:59 PM
I'm getting this....
08-15-2023 02:02 PM
...and what is CLI...
08-16-2023 05:20 AM
Hi @Ant
Thanks for your response.
Please use the below mentioned credentials to login into putty.
Usernames: Passwords:
admin sp-admin
super Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
Once you logged in please share the output of the following commands.
Show flash
Show version
