Power surge happen today and after that ruckus is not coming online
Vasayasultan
How can we get help for icx 7150 to turn on
1 ACCEPTED SOLUTION
Hi @Vasayasultan
As you mentioned there are lights on the PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. This is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
We will try to reset the Switch as described below VIDEO:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
Video link: https://www.youtube.com/watch?v=6jHMTdo_hK4
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Video Link: https://www.youtube.com/watch?v=Ql22blH_CGo
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
19 REPLIES 19
Hi @Vasayasultan
Have you tried logging in with the default credentials provided below? If not, please try and let me know if any of them work.
These usernames and passwords are key-sensitive, please use capital letters where necessary.
Hi @Vasayasultan
Thanks for your response,
Please confirm whether you have created the password successfully and also let us know whether you could log into your switch.
Yes all done with the last set of codes
Hi @Vasayasultan
Good to know that the issue got resolved.
