11-13-2023 07:28 PM
How can we get help for icx 7150 to turn on
11-15-2023 07:18 AM
Hi @Vasayasultan
As you mentioned there are lights on the PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. This is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
We will try to reset the Switch as described below VIDEO:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
11-14-2023 09:38 AM
Hi @Vasayasultan
As per the case description, I understand that your RUCKUS setup is not working after a power outage.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
11-14-2023 04:10 PM
1. It was working since 2019
Yes there was a power outage
2.yes there is light on it like power is green and syst is amber
3.yes I have internet service in the house
4.access point are no light at all
11-15-2023 07:18 AM
Hi @Vasayasultan
11-18-2023 07:01 AM
Reset worked but after a lot tries.
So I don't have to update or any right?
Currently it's on version 08.0.90dT211
Both partion
Please reply
