Power surge happen today and after that ruckus is not coming online
Vasayasultan
How can we get help for icx 7150 to turn on
1 ACCEPTED SOLUTION
Hi @Vasayasultan
As you mentioned there are lights on the PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. This is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
We will try to reset the Switch as described below VIDEO:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
Video link: https://www.youtube.com/watch?v=6jHMTdo_hK4
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Video Link: https://www.youtube.com/watch?v=Ql22blH_CGo
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
19 REPLIES 19
Hi @Vasayasultan
We suggest upgrading your Switch. The recommended stable version is 8095g (08.0.95g)
Please follow the below steps explaining the Upgrade process.
The Upgrade path would be: 08090d (your current version) >>8095g
(PLEASE NOTE: Use 08095g patch in place of 8095h as explained in the guide and please IGNORE 8080f)
Your Upgrade folder should contain these 1 file shown in the below screenshot: (Refer the guide link for more information)
Below are the options or methods to perform the Upgrade on the switch: You could choose any one of these.
1st Option:
1. In this option, we will use a pen drive or USB flash drive in which we move the files to the pen drive and connect it to the Switch then through CLI we execute the commands to upgrade the Switch using the following guide as a reference:
2nd Option:
2. The following guide is an example of an upgrade via TFTP server, by using an application (FREE) to send files or upload remote files to a device, in our case, we will use it to update a new version to the Switch, basically it will send the image version remotely from the computer to the switch.
3rd Option:
3. In this option we Upgrade the Switch from the Web Interface (GUI) of switch.
https://0.0.0.0 or http://0.0.0.0 (IP address of Switch. 0.0.0.0 is just as an example)
If you can access CLI, I would suggest you follow the 2nd option.
i upgrade with gui and now i cant log in to icx7150 switch.
i can log in to my network but switch is diconnected and ask user name and password
i tried my password as well as all other given by the example but no success
can you help
Hi @Vasayasultan
Thank you for the response and the details.
Could you please log into the CLI and the output of below mentioned commands?
show version
show flash
HR COM3- PuTTY
ICX7150-C12 Switch>enable
No password has been assigned yet ...
ICX7150-C12 Switch#show version
copyright c) Ruckus Networks, Inc. All rights reserved
UNIT 1: compiled on Feb 23 2021 at 00:00:27 labeled as SPS08090k
(29360128 bytes) from Primary SPs08090k.bin (UFI)
SW: Version 08.0.90kT211
Compressed Primary Boot Code size = 786944, version:10.1.18T225 (mnz10118)
Compiled on Mon Jul 13 08:53:29 2020
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:FEK3812R0JB
Software Package: BASE_SOFT PACKAGE
Current License: 2X10GR
P-ASIC : type B160, rev 11 chi BCM56160 BO
UNIT 1: SL 2: ICX7150-2X1GC 2-por
UNIT 1: SL 3: ICX7150-2X10GE 2-a
1000 Mhz ARM processor ARMv7 88 MHZ bus
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 16 hour(s) 58 minute (s) 59 second(s)
The system started at 00:02:42 GMT+00 sat Jan 01 2000
ICx7150-C12 Switch#show flash
stack unit 1:
Compressed Pri Code size = 29360128, Version:08.0,90kr211 (SPS08090k.bin)
Compressed Sec Code size = 28660224, Version:08.0.90dT211 (SPS08090d.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.187225 (mnz10118)
Compressed Sec Boot Code size = 786944, Version:10.1.15r225 (mnz10115)
Code Flash Free space = 1133465600
ICX7150-C12 switch#
Hi @Vasayasultan
As I see your Switch is on the 8090k version. Could you please update the Switch on the 8095g stable version as explained in detail in my upgrade post?
I would suggest upgrade the Switch using 2nd option using CLI.
