11-22-2022 07:29 AM
Hi, I have been dealing with slow wifi for a while now. The system came with Lennar home. I tried to reset everything but that didn’t help.
Any suggestions on what i should do? Thanks
11-22-2022 07:38 AM - edited 11-22-2022 07:38 AM
Hi @DeanT
Hope you are doing well !
If there was a power outage most possible that switch start running the wrong code for that reason there are many symptoms
Smart devices like Amazon's Alexa not working as intended.
Unleashed dashboard sometimes not showing as "Connected" on the Internet tab.
Websites not loading.
Several connectivity issues.
An identifier of this problem is that it comes out as Switch-Router in the unleashed dhabsoard.
MAC address: Physical address of the device this never changes
The IP address : is a logical address assigned by your local router to the device (this can change and may not be the same as the one shown on the dashboard)
1- To fix this issue, we must identify the IP address of the switch 'currently'
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not I will leave you a guide how to perform a IP scanner on your local network to identify the switch IP.
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
3-Here is a quick guide to understand how to fix the 'routing code issue' but basically you need only need to run the following commands once you are on the command line 'CLI'
copy flash flash secondary
example:
ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait : until the flash finished )
ICX7150-24P Router#boot system flash secondary yes ( hit enter to accept the command : the switch will reboot )
How to Fix Routing code issues on Lennar Home users
4-If the access via IP address is not possible here is a guide how to access using a console cable ( usb to usb type C )
Once you are log in the ICX-7150-C12P please follow up the same steps that are on point '3'
Best Regards
Fernando Vasquez
11-25-2022 12:33 PM
Hi, I ran the commands you specified but it's giving me an error. How should I proceed?
SSH@ICX7150-C12-Router>enable
SSH@ICX7150-C12-Router#copy flash flash secondary
Unable to find a UFI image copy from. Please reload master with appropriate UFI image to proceed with flash-flash copy
11-25-2022 12:42 PM
Hi @DeanT
Thanks for the update !
could you please run the following commands :
Show version
show flash
Also most possible you need to perform an upgrade to the switch here are a couple of guides how to do it:
How to perform an Upgrade via Web GUI (ICX7150 Switch)
Best Regards
Fernando Vasquez
12-04-2022 05:31 PM
I follow direction to copy files from USB but here what I got
SSH@ICX7150-C12-Router#copy disk0 flash mnz10114.bin bootrom
Invalid input -> bootrom
Type ? for a list
version:
HW: Stackable ICX7150-C12-POE
Serial #:FEK3833R0BL
Software Package: ICX7150_BASE_L3_SOFT_PACKAGE
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
Show flash:
Stack unit 1:
Compressed Pri Code size = 28660224, Version:08.0.90dT211 (SPS08090d.bin)
Compressed Sec Code size = 32539748, Version:08.0.90dT213 (SPR08090d.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Compressed Sec Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Code Flash Free Space = 1260425216
