11-22-2022 07:29 AM
Hi, I have been dealing with slow wifi for a while now. The system came with Lennar home. I tried to reset everything but that didn’t help.
Any suggestions on what i should do? Thanks
12-06-2022 07:23 AM
I am stuck on what I should do. Please see my issue in the other message as I was not able to copy files from USB.
Thank you,
12-06-2022 07:27 AM - edited 12-06-2022 07:28 AM
Hi @DeanT
Could you please run the following command
Mount disk0
Show files disk0
Send me what you get from there.
Best Regards
Fernando Vasquez
12-06-2022 05:28 PM
SSH@ICX7150-C12-Router>show files disk0
F 786944 mnz10114.bin
F 25976488 SPS08080f.bin
F 58690107 SPS08095hufi.bin
D 16384 [----] disk0/System Volume Information
85453539 bytes 3 File(s) in disk0
SSH@ICX7150-C12-Router>mount disk0
Invalid input -> mount disk0
Type ? for a list
12-07-2022 04:28 AM - edited 12-07-2022 04:29 AM
Hi @DeanT
1-Could you please go to 'enable mode' type the following command since you are on a version later than 8080f we can omit that setup and go to 8095h directly
Enable
Then Please run the following command
copy disk0 flash SPS08095hufi.bin secondary
write memory
Boot system flash secondary yes
Best Regards
Fernando Vasquez
12-07-2022 05:31 PM
I did those commands and it went through. However, the wifi is still inconsistent and disconnecting.
What is the next step?
