07-10-2023 08:10 AM - edited 07-10-2023 08:18 AM
I have a ICX 7150 since 2020 and was never upgraded. I am at a lost as to how to locate the version and then what upgrade is necessary to use. Any help would be appreciated.
07-10-2023 08:30 AM
Hi @MiSNemesis
The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin
Please follow the below guides to perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin to avoid the issues in future.
07-10-2023 01:08 PM
SSH@ICX7150-C12 Switch#show version
UNIT 1: compiled on Apr 11 2023 at 00:06:30 labeled as SPS08095j
(31457280 bytes) from Primary SPS08095j.bin (UFI)
SW: Version 08.0.95jT211
Compressed Primary Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compiled on Tue Nov 29 08:43:26 2022
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:FEK3203P15K
Current License: 2X10GR
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
SSH@ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Sec Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Code Flash Free Space = 1110274048
SSH@ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 On Off 0 0 n/a n/a 0 n/a
1/1/2 On Off 0 0 n/a n/a 0 n/a
1/1/3 On Off 0 0 n/a n/a 0 n/a
1/1/4 On Off 0 0 n/a n/a 0 n/a
1/1/5 On Off 0 0 n/a n/a 0 n/a
1/1/6 On Off 0 0 n/a n/a 0 n/a
1/1/7 On Off 0 0 n/a n/a 0 n/a
1/1/8 On Off 0 0 n/a n/a 0 n/a
1/1/9 On Off 0 0 n/a n/a 0 n/a
1/1/10 On Off 0 0 n/a n/a 0 n/a
1/1/11 On Off 0 0 n/a n/a 0 n/a
1/1/12 On Off 0 0 n/a n/a 0 n/a
Total 0 0
--More--, next page: Space, next line: Return key, quit: Control-c
SSH@ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
07-10-2023 01:20 PM
Hi @MiSNemesis
The output of the commands seems normal.
Could you please let me know if your Access Points have any of the lights ON?
07-10-2023 01:25 PM
No lights at all. when I look at the Switch, there is no connection going on with the network cables. I rebooted the switched and remove and plug the cables back in. Still no lights.
07-10-2023 01:28 PM
Hi @MiSNemesis
Could you please plug the APs ethernet cable on other ports (any within 12 ports as shown in the below screenshot) and try check the AP again?
07-10-2023 01:33 PM - edited 07-10-2023 01:35 PM
I removed and move to another empty port. Still no lights.
