08-29-2023 09:02 AM
I have been using RUCKUS for more than three years and never had a any issues. Past from few days I challenges to access Internet through RUCKUS
appreciate if you could help me to resolve this.
Jyothi
09-05-2023 12:18 PM
Hi @Jyothik16
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
We suggest upgrading your switch to the latest stable version to avoid this issue in the future. Your Switch is on an older version that is 08080d. Please let us know once you complete the above process to assist you with the Upgrade of the Switch.
09-06-2023 08:57 AM
Seems like it’s stable. In the morning when I looked at RUCKUS upstairs it showed all red lights but now it doesn’t.
Thank you for all you timely response and guidance to resolve the issue.
Jyothi
09-04-2023 02:49 PM
Downstairs
Upstairs
09-04-2023 02:49 PM
Yes, internet is working using local provider router
09-04-2023 03:00 PM
Hi @Jyothik16
As per the pictures you shared, light status of the Switch and the Access Point seems to be normal.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
09-04-2023 04:48 PM
I could locate IP address and opened putty. But it does not give me any command line to execute rest of the command lines as described in the follow pages
09-04-2023 04:53 PM
Hi @Jyothik16
May I please know what is the error you are getting on Putty when you are trying to access the Switch CLI? Please share the screenshot of the same.
