08-29-2023 09:02 AM
I have been using RUCKUS for more than three years and never had a any issues. Past from few days I challenges to access Internet through RUCKUS
appreciate if you could help me to resolve this.
Jyothi
09-05-2023 12:18 PM
Hi @Jyothik16
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
We suggest upgrading your switch to the latest stable version to avoid this issue in the future. Your Switch is on an older version that is 08080d. Please let us know once you complete the above process to assist you with the Upgrade of the Switch.
09-06-2023 08:57 AM
Seems like it’s stable. In the morning when I looked at RUCKUS upstairs it showed all red lights but now it doesn’t.
Thank you for all you timely response and guidance to resolve the issue.
Jyothi
09-06-2023 08:19 AM
Hi @Jyothik16
Please perform the below commands and share the output to check and confirm your current version on the Switch.
show version
show flash
09-06-2023 08:43 AM
09-06-2023 08:50 AM - edited 09-06-2023 08:51 AM
Hi @Jyothik16
Great!!! As I can see from the screenshot you shared, your RUCKUS ICX-7150-C12P Switch is now upgraded to a latest UFI version.
Could you please confirm if your Internet connectivity via RUCKUS devices is stable?
NOTE: I would appreciate you, mark the Upgrade post as ACCEPTED SOLUTIONS if I was able to help you with the same.
09-06-2023 08:57 AM
Jyothi
09-06-2023 09:14 AM
Hi @Jyothik16
Was there a RED light on the PWR or AIR, since apart from PWR and AIR there won’t be Red lights?
Please refer to the below link for more information about the light status of the RUCKUS R510 Access Point.
