Channel status of AP R310 connected to smart zone 100
CHOIYOUNGJAE
Hello.
We will contact you to try to resolve the issue.
Now I have AP R310 connected to smart zone 100.
When I connect to the controller web and see the access points tab, the channel assigned to the AP is showing as N/A.
If the channel shows as N/A, does the AP work fine?
Or is it not working because no channel is assigned?
What is the problem, if any, that I don't know about?
Do you know what the solution will be?
※ I tried to attach a picture for easy understanding, but it failed due to lack of permission.
Verification please.
thank you.
2 ACCEPTED SOLUTIONS
simon_louis
RUCKUS Team Member
Hi @CHOIYOUNGJAE
Please check if the AP config status is up to date.
Are there other AP's in the same zone as this R310 AP that are broadcasting ssid?
Can you please login to the AP CLI and run the command get wlanlist to verify if the AP has the configured ssid present.
Below mentioned article link looks similar to the issue which you have described:
https://support.ruckuswireless.com/articles/000009910
Let me know if it helps.
Simon Louis
Hi @CHOIYOUNGJAE
I see you quoted "Now I have AP R310 connected to smart zone 100." are these new APs added to the controller ?. If Yes then we might need to f/d them if they were on ZD code earlier. Apart from that when the APs do not have an active WLAN assigned to radio the channel shows N/A hence make sure WLAN is mapped to these APs "get wlanlist".
Best Regards
Vineet
6 REPLIES 6
hello!
This problem is solved. After unlocking, select Connect. Thank you for your reply as you are busy.
hello!
