07-19-2024 03:52 PM
so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
08-01-2024 08:04 AM
Hello @LD ,
08-02-2024 08:54 AM
Hi @LD ,
Thank you.
07-24-2024 10:13 AM
Hello @LD ,
Could you please confirm if you are able to login to the Switch dashboard with the default credentials after the reset is completed?
Please update us once you are able to login to the Switch dashboard.
08-02-2024 01:45 PM
I will try the access on weekend, there should be no problem
08-02-2024 02:03 PM
Hello @LD
Greetings,
Thank you for your response.
Please keep us updated on the progress, and let us know if you require any assistance at any point during the process.
