WiFi inconsistent, internet speed go hi and low. Forgot id and password.
LD
so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
32 REPLIES 32
Hello, Thankyou for following up. I tried to reset the ruckus by doing the same as in video, but i think it did not reset since we could connect to WiFi and could not access the command line by default passwords. So reset did not happen I guess.
pinky_ruckus
Valued Contributor III
test
pinky_ruckus
test
pinky_ruckus
Hello @LD ,
I understand that you are unable to login to the CLI  using the IP address of the Switch even after the hard reset.
I would request you to please try logging into the CLI of the Switch using the Telnet option which doesn’t require credentials.
Please login to the CLI of the Switch as described in the below screenshots.
Once you can access through Telnet, it should look like this:
Accessing CLI on MAC terminal using Telnet option
????telnet@ICX7150-12P Switch>
Once we get the above prompt, we can execute the required commands.
telnet@ICX7150-C12 Switch>enable
telnet@ICX7150-C12 Switch>show version
telnet@ICX7150-C12 Switch>show flash
pinky_ruckus
Hello @LD ,
