07-19-2024 03:52 PM
so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
07-23-2024 06:33 AM
Hello @LD ,
Could you please confirm if you are getting the dashboard as shared in the previous post?
Also, please share the screenshot when you enter the IP address of the Switch in the web browser.
07-23-2024 07:06 AM
Yes it’s the dashboard, here is the screenshot, what to do next?
07-23-2024 07:54 AM
Hello @LD ,
From the screenshot you shared, it seems that the Ip address you are trying is of the Access point and not the Switch.
If you are using the IP address of the Switch, you will get the Switch dashboard with the option to login to the Switch.
I recommend cross-checking the IP addresses listed in the IP scan results under the names "Ruckus Wireless" or "Brocade Communications" to identify the correct IP address of the Switch and proceed to access the web browser accordingly.
07-23-2024 08:23 AM
Got it
07-23-2024 08:37 AM
Hello @LD ,
From the screenshot you shared, I understand that you are able to access the Switch dashboard using the correct IP address.
Could you please try accessing the CLI using the same IP address and confirm if you are able to access the CLI ?
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
