WiFi inconsistent, internet speed go hi and low. Forgot id and password.
LD
so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
32 REPLIES 32
Entering the above method with command line but getting this error
—— ssh [email protected].
——“Unable to negotiate with 192.168. port 22: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group1-sha1”
pinky_ruckus
Valued Contributor III
Hello @LD ,
From the previous post, I see that you are able to see the Switch dashboard using the IP address in web browser.
Could you please try logging in to the  Switch dashboard?
Switch default credentials will be as mentioned below.
Username: super
Password: sp-admin
If the above credentials don’t work, you can try the default credential combinations below as well.
These usernames and passwords are key sensitive, please use capital letters where necessary.
when I sign in it keep login and form gets blank and when I cancel, /home page appears with notice — protected object - this object on the bar code comm system server is protected. Return to last page link
LD
 This is from Crome browser. Tried all the id and passwords
pinky_ruckus
Hello @LD ,
If any of the credentials in the previous post don’t work, please try to factory reset the RUCKUS ICX-7150-C12P Switch as described below in the below VIDEO or the article below and once you perform the reset try to log in with the default credentials again.
VIDEO link: https://www.youtube.com/watch?v=6jHMTdo_hK4
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to hard reset the Switch
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy...
