07-19-2024 03:52 PM
so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
07-23-2024 09:56 AM
Entering the above method with command line but getting this error
—— ssh [email protected].
——“Unable to negotiate with 192.168. port 22: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group1-sha1”
07-23-2024 10:25 AM
Hello @LD ,
From the previous post, I see that you are able to see the Switch dashboard using the IP address in web browser.
Could you please try logging in to the Switch dashboard?
Switch default credentials will be as mentioned below.
Username: super
Password: sp-admin
If the above credentials don’t work, you can try the default credential combinations below as well.
These usernames and passwords are key sensitive, please use capital letters where necessary.
07-23-2024 10:46 AM
when I sign in it keep login and form gets blank and when I cancel, /home page appears with notice — protected object - this object on the bar code comm system server is protected. Return to last page link
07-23-2024 11:00 AM
This is from Crome browser. Tried all the id and passwords
07-23-2024 11:18 AM
Hello @LD ,
If any of the credentials in the previous post don’t work, please try to factory reset the RUCKUS ICX-7150-C12P Switch as described below in the below VIDEO or the article below and once you perform the reset try to log in with the default credentials again.
VIDEO link: https://www.youtube.com/watch?v=6jHMTdo_hK4
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to hard reset the Switch
