Ruckus box not working ( no power signal)
Panirajh04
we had power outage in the morning, post that I am not Gettig any power in the Ruckus box
I tried unplugging the power, not change . any solution greatly appreciated
1 ACCEPTED SOLUTION
pinky_ruckus
Valued Contributor III
Hello @Panirajh04 ,
As per the case description, I understand that you have received a replacement Switch and need assistance in setting up your system.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/RUCKUS-Lennar-Home-devices-C...
Should you require further assistance or have any questions, please do not hesitate to reach out.
22 REPLIES 22
Hi @Panirajh04
Greetings, and thank you for your response and the update.
Upon reviewing the image you shared, I noticed that one of the Software Recovery cables is connected to an incorrect port. Kindly reconnect the cable to the correct port as shown in the screenshot below, then restart the laptop and retry the recovery process.
Please let me know the outcome after trying this.
I reconnected the cable as shown in the picture, restarted and tried again
no changes
Hi @Panirajh04
Thank you for sharing the detailed information.
Based on the information provided, it appears that you are encountering issues with the RUCKUS ICX-7150-C12P Switch stuck in boot mode and you tried the recommended troubleshooting steps with no luck in getting it fixed.
Based on the troubleshooting conducted, it appears that your ICX-7150-C12P Switch is currently stuck in boot mode. You have followed the recommended troubleshooting steps, such as resetting with a paper clip and performing a Software Recovery. However, the issue persists.
Given these circumstances, the switch will need to be processed for an RMA (Return Merchandise Authorization), which essentially means that it should be replaced.
Feel free to contact us via chat. Copy and share the link from the post (URL), and paste it into the chat when prompted to start the unit replacement.
Please follow the steps as shown in the example below:
As shown in the picture below, copy the link and share it via chat from the link provided:
HI Imran
I received new box , are there any instruction to be followed before change to new box
pinky_ruckus
Hello @Panirajh04 ,
