04-30-2025 10:11 AM
we had power outage in the morning, post that I am not Gettig any power in the Ruckus box
I tried unplugging the power, not change . any solution greatly appreciated
05-20-2025 01:04 PM
Hello @Panirajh04 ,
As per the case description, I understand that you have received a replacement Switch and need assistance in setting up your system.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
Should you require further assistance or have any questions, please do not hesitate to reach out.
04-30-2025 11:19 AM
Hi @Panirajh04
Based on the information provided, it appears that your RUCKUS setup is not working after a Power Outage.
When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
Please log in to your RUCKUS Account before uploading these photos/screenshots.
Please help me with the above query, and should you have any further questions or concerns, feel free to reach out.
04-30-2025 12:30 PM
HI Imran
Attached the photoi can see two light , one orange and green
there is no light or signal on this
04-30-2025 12:39 PM
Hi @Panirajh04
Thank you for your response and for providing the information.
Based on your description, the Orange/Amber SYST LED on your RUCKUS ICX-7150-C12P switch indicates that the device is stuck in boot mode.
To resolve this issue, please refer to the following RUCKUS Lennar Support Knowledge Base article, which provides step-by-step instructions:
If you need any assistance while following the guide, feel free to reach out. I’ll be happy to help.
05-01-2025 04:31 PM
HI Imran
I have gone through in detail, restart did not work for me
I went through other option, i could not find any files in the repository mentioned in the link, do we have any other resources
