04-30-2025 10:11 AM
we had power outage in the morning, post that I am not Gettig any power in the Ruckus box
I tried unplugging the power, not change . any solution greatly appreciated
05-20-2025 01:04 PM
Hello @Panirajh04 ,
As per the case description, I understand that you have received a replacement Switch and need assistance in setting up your system.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
Should you require further assistance or have any questions, please do not hesitate to reach out.
05-07-2025 03:50 PM
HI Imran
Thanks for the files, I followed as per the instruction provided
i am not able to get com3 on the device manager
I am seeing Standard serial over Bluetooth link (COM3)
i opened putty and entered COM3, putty has opened not able to edit anything in the putty
Can you help on this
05-08-2025 05:46 AM
Hi @Panirajh04
Please note that the COM port does not have to be COM3 specifically; it can be any available COM port. However, it should be the one labeled with 'Silicon Labs' as the device name.
Please make sure to download the zip drive for the file below & "extract all". Once it's extracted, run the file, the driver should be installed using the 2 links below.
Link 1: https://support.ruckuswireless.com/software/1414-brocade-ruckus-7150-usb-serial-driver-windows
Link 2: silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
Once installed restart your laptop and try to locate the COM port details under 'Ports (COM & LTP)' with cables connected between the Laptop and the Switch (Refer to the below screenshot), Please check and let me know if that works.
05-10-2025 12:52 PM
HI Imran
I followed the above steps, installed the downloads as instructed above
still I could not find the Silicon Labs COM files
05-12-2025 05:23 AM
Hi @Panirajh04
Could you please share a picture showing the Software Recovery cable connections between the RUCKUS ICX-7150-C12P Switch and the Laptop?
05-12-2025 05:46 PM
HI Imran
Attached the photo for reference
white and black cable
