Ruckus box not working ( no power signal)
Panirajh04
we had power outage in the morning, post that I am not Gettig any power in the Ruckus box
I tried unplugging the power, not change . any solution greatly appreciated
1 ACCEPTED SOLUTION
pinky_ruckus
Valued Contributor III
Hello @Panirajh04 ,
As per the case description, I understand that you have received a replacement Switch and need assistance in setting up your system.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/RUCKUS-Lennar-Home-devices-C...
Should you require further assistance or have any questions, please do not hesitate to reach out.
22 REPLIES 22
Hi @Panirajh04
As discussed, please attempt the reset process multiple times using a paper clip, following the provided instructions carefully.
If the reset is unsuccessful, the next step would be to proceed with a software recovery of the switch. If you’ve already started this process, kindly let me know which step you are encountering difficulties with, and share relevant screenshots for further assistance.
Please don’t hesitate to reach out if you have any questions or need additional support.
RUCKUS Lennar Home Community Support
Hi Imran
I have attempted the reset process multiple times using a paper clip , all the lights blink and goes off. i tried more than 10 times but the same result
i started going through software recovery of the switch, when I went to repository for downloading the software, nothing is available in the link
TFTP 64 not available in the link provided below  https://bitbucket.org/phjounin/tftpd64/downloads/
Also, could not be able to find 8090K file in the download, nearest file available is 8095 (ICX7150>downloads>choose the code>I will choose 08090k)
can you help to share those two files
can you please share these two files, I will try for next steps
For Boot: mnz10115.bin
For Image: SPS08090k.bin
Hi @Panirajh04
I sincerely apologize for any inconvenience caused.
Please use the Google Drive link below to download the TFTP64 application along with the requested Software Recovery patches:
https://drive.google.com/drive/folders/1bi2LOVqXDZvv_SU188gEc5_vwTt4jhfD
If you need any assistance during the process, feel free to reach out.
Ruckus | Lennar Home Community Support
Hi @Panirajh04
Thank you.
